by Mr DJ » Sun May 16, 2010 7:39 pm
Playdo setup, cause it's not as big in diameter (tad longer tho) as the 80, plus the booster is then matched to the master.
80 master will bolt up to the hilux booster for disc/disc but pedal is not great I'm told, due to the booster not being as big.
The Playdo master won't just bolt up to hilux booster, so you'll need the booster to go with it.
You probably already know, but an 80 master can be disc/drum or disc/disc so make sure you get the right one for your application.
"There are a number of mechanical devices which increase sexual arousal, particularly in women. Chief among these is a Pumped Up Surf."
91 Hilux Surf, with a few extra's ....
SAS by
http://www.budscustoms.com.au
