Power Steering setup for a 82 Hilux
Postby ap7 » Wed Jul 07, 2010 4:49 pm
Hi,
I am after a complete power steering setup for my 82 Hilux. It is getting hard to turn the steering with 35's on!
My hilux details are as follows:
- RN46 (1982 Hilux)
- Holden 253 engine
[img]http://i653.photobucket.com/albums/uu255/ap2276/Hilux%204x4/DSC02554.jpg[/img]
[img]http://i653.photobucket.com/albums/uu255/ap2276/Hilux%204x4/DSC02556.jpg[/img]
As I am a novice, I would prefer a kit or if someone can help me fabricate it I would be most appreciative!
Also, would be interest in a disc brake conversion for the Hilux if anyone can help?
Thanks
ap7
Postby BobLux » Wed Jul 07, 2010 9:03 pm
Contact Matt @ Phats4Runners in Gosford, he breaks Gen1 4Runners, same running gear. He also does engine conversions V6 & V8s into these trucks so he should be good for some advice.
I got my power steering set up from him, he's a sound guy, very helpful, and his prices are very fair. He'll also help you with the brakes.
He's on Ebay http://myworld.ebay.com.au/phats4runners/
Or phone him: 0432274467
Hope this helps.
95 80 series, 4.5 petrol, 33"s 2", the usual touring stuff..
85 4Runner, 2.4 Diesel, 2" lift, 33"MTZs, 4.88 Diffs, 4.7 Reduction Gears.
BobLux
Postby ap7 » Fri Jul 09, 2010 3:08 pm
Thanks m8, but he couldn't help with the power steering setup....
ap7
Postby red92gq » Sun Jul 11, 2010 9:18 pm
Just use steering box off 85 model an holden pump.You can get brackets to mount the pump on either side of motor,an box should bolt straight on.(you may have to use part of the steering column shaft from the 85 as well)
You will have to get the hoses made up to suit ,any hydraulic shop can make these up for you
red92gq
Return to Technical Information
