ARB locker information
Postby Taziiy » Tue Jan 23, 2007 10:37 pm
ARB Air Locker
Wiring Diagrams
ON COMMAND LOCKERS
ARB Air Locker:
The ARB Air Locker is a unique air operated unit, for which the locking action is controlled by the driver with a push of a button inside the cab. A 12-volt air compressor (24 volt also available) engages the unit in approximately 1 second and can be engaged at any vehicle speed. 100% drive to each wheel when the unit is locked up. While the unit is unlocked there are no handling problems, or additional wear problems. Unit can NOT be engaged while a wheel or wheels are slipping. Any good pump that supplies 95 to 115 lbs. of air pressure will work in place of the ARB pump. If the customer purchases both the ARB pump and the ARB differential, all of the parts needed are included, even the wiring.
SEE THERE ONLINE MANUAL HERE
COMPRESSOR WIRING DIAGRAMS
[SIZE="5"]RDCKA 12 volt[/SIZE]
[SIZE="5"]RDCKA24 24 volt[/SIZE]
[SIZE="5"]CKA12 12 volt[/SIZE]
Return to Technical Information
